jaybo 10 Posted October 19, 2016 I've split my frotn lights apart and given the glass and reflectors a good clean and they now look brand new but the fogs and indicators now look pretty old/dirty. Is it possibe to split these apart with a heat gun to get inside and clean them? If so what have people been using to reseal them? Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted October 19, 2016 Risky, you could crack the Glass if heated too much, How Will you Know when they are too hot? The sealant sers Like concrete and very difficult to remove, both off the glass and worse still out of the actual housing and that's if you get the glass of in 1 piece.. The only sealant I ever use when replacing the lense is made by Sika, white marine sealant used on boats. Try it, you might be lucky and succeed. Quote Share this post Link to post Share on other sites
jaybo 10 Posted October 19, 2016 Hmmm..youve scared me off the job now lol. Is there an easier way to clean? Soak in vinegar or hot water? Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted October 20, 2016 Wasn't my intension Jay, just to warn you of the possible consequences.. The cleaning is the least of the problem, it's actually getting them dried out afterwards that's the bugger. I've tried dunking them in hot, soapy water and then force drying them with compressed air, fine on the outer bits but thanks to the metal bulb cover (At least on the second series lamps) you cannot get to the center part of the light, the air will just force the water side to side.. Bent pipe cleaners could also work. Give it a go mate, nothing to loose 'cause if you do break a glass i have spare foglamps available!! Quote Share this post Link to post Share on other sites
seanl82 23 Posted October 20, 2016 A cheap babies bottle brush and bend it to get inside of the glass will probably work. Just be careful on the reflective part as they have a nasty habit of peeling off! Quote Share this post Link to post Share on other sites
