thamouse1981
Corrado vr6 aqua blue £4200
So I originally purchased this 1.5 years ago with a view to keep it as an investment car hoping values would increase. Unfortunately not having storage and a young son taking up all my free time means it is no longer an option for me and it's now going for sale. The details:
Corrado VR6 94100 miles on the car 29000 miles on brand new VAG engine fitted in 2005 at a cost of 4200!, 12 months mot, grey cloth interior, cd player with Bluetooth playback, pioneer speakers in original positions and sizes, storm force car cover, K&N induction kit, sunroof tilts and slides, e/w, e spoiler, e mirrors, vgc benefiting from front and side respray,
FSH up to 92k but now out of date by 19 months ( only 2k miles covered) 10k vw, 18k vw, 27k vw, 35k vw, 41k vw, 47k vw, 50k vw, 50k vw, 60k ind, 65k vw, 72k ind, 77k audi, 81k vw, 87k ind, 92k ind 04/15
Every MOT since 1999
BBS 17in RX2 split rim alloys with brand new kumho tyres x4
Brembo 323mm front brake upgrade with braided hoses
Mk 4 rear brake upgrade with braided hoses
Koni shocks and springs with damper adjustment
New rear brake calipers, pads, discs, bearings and abs rings and sensors (both sides) 2015,
New battery 2016
Vibratechnic front mount and new gearbox mount 2015
Thermostat housing, various sensors, spark plugs, link arms and service 2014 cost £898
New clutch 2014
New radiator 2013
There is loads more work with receipts dating back to 2000
So now I will tell you the known bad points:
Top of the windscreen drivers side has a 2 x 1 inch sections of bubbled rust just coming through.
Seems to be some abs chatter when stopping at low speed and pedal pressure brakes work fine just appears to activate abs at less than 5 mph I suspect the n/s reluctor wheel/hub. Car was stood for 3 months prior to last week when I drove it put an abs light on that went away post ignition cycle and hasn't returned hence passing the mot today
Grey cloth is in good condition bar drivers side upper and lower bolster worn through
Tracking is a little off but not much the front wheels are cambered aggressively in, I like the look but may not be everyone's taste
Slight vibration at speed through steering wheel maybe weights fallen off a wheel
Ultimately I want it gone but would like for it to go to some who will drive it, it doesn't deserve to be sat doing nothing like It has for 18 months. Price drop to 3800
Edited by thamouse1981
Price drop to 3800
Thankyou I have better images but am struggling to upload, I will continue to try
The ones on Facebook?
Now with more photos taken today, showing the windscreen bubbling and 2xrust spots on the sill 1 picture captures them both but I tried to take close ups, there is no MOT advisories.
Yep that should be fine there are quite a few on there do you have any specific areas? Or just the main ones what's your email address
Hi,
I am in the market for a good VR6 and am very interested in your Corrado. I live in Bristol which isn't too far from yourself and would be interested in seeing it but I have a few questions:
1. The rust marks on the sills: You haven't mentioned this on the bad points but is on the photos. Is this just surface rust or are they rotten?
2. Tracking: I assume this can be adjusted back to normal settings with just a trip to kwik fit etc?
3. 29k engine: Does it run and drive as you'd expect a engine with that little mileage to do?
4. Bodywise, aside from the rust spots is this in excellent condition? Can you tell it has been sprayed?
5. ABS: Do you think this is just a sensor issue?
From the photos it looks fairly standard, does it look that way despite the koni suspension etc? ie. is it lowered etc, and if so would it be easy to put back to normal?
Thanks,
Tim.
Hi sorry about the delay in the reply, I haven't looked at the forum for a couple of days, there are two rust spots on the car on the sills each about 4cm long these look like they have been previously treated but not painted. The MOT man said they were solid enough so didn't put it as an advisory, when the car was Resprayed I assumed they would include it as well but because I didn't point it out they didn't see it...Apparently! They then quoted 150 + vat to get that done as well which I just didn't. It's not so much tracking but the camber on the front wheels 4 wheel alignment would correct it. The engine drives and sounds superbly and is the main reason I bought the car. Bodywork wise in a normal look the car look immaculate if you look closer on the front bumper the finish is slightly orange peely. I think the ABS is a front hub reluctor wheel issue but it doesn't really affect the drive or brake operation hence why I haven't fixed it. It looks fairly standard but would be too easy to return to standard due to the brakes not allowing speedline alloy wheels due to size. Please contact for any more info.
Many thanks
Hi. Thanks for your reply to my questions. I am interested in the car and would be able to come see it next Thurs (24/11) if that was possible as I am near the area. Would you be in around lunchtime (thats if you haven't sold the car by then!)?
If so I have a few other questions:
1. Does the car have current insurance/tax for a test drive? (My insurance policy allows me to drive any car as long as it is insured)
2. Is the car ready to be driven away that day?
Many thanks,
Tim.
