yalan 0 Posted July 11, 2004 On my spacesaver.... originally has a 125 width tyre. ..... but can only find 115 wide at (any) breakers. can I get away with it? (apparently, according to elite, continental have stopped making 125/70/15 ! ) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 11, 2004 A can of Tyreweld is just as good as a spacesaver in most circumstances Quote Share this post Link to post Share on other sites
dinkus 10 Posted July 11, 2004 You need the full size spare option :) Didn't want to fit anything in the boot anyway... Quote Share this post Link to post Share on other sites
yalan 0 Posted July 11, 2004 A can of Tyreweld is just as good as a spacesaver in most circumstances aah but then you end up with a tyre full of that sticky cr*p which needs cleaning out before doing a proper repair. Personally I don't fancy doing 70+mph with a tyre I know has a hole in it.......... Quote Share this post Link to post Share on other sites
Musicman 0 Posted July 12, 2004 A can of Tyreweld is just as good as a spacesaver in most circumstances aah but then you end up with a tyre full of that sticky cr*p which needs cleaning out before doing a proper repair. Personally I don't fancy doing 70+mph with a tyre I know has a hole in it.......... 70?! Spacesavers are usually only rated for 50 mph... I don't think you should be doing 70 in either case. Quote Share this post Link to post Share on other sites
yalan 0 Posted July 12, 2004 ha-ha - bloody 'ell no, not 70 on a spacesaver! But anyway - back to the point - can you put a 115 tyre on a rim designed for 125s ??? Quote Share this post Link to post Share on other sites
