Eug
Clicking noise
Can someone explain this ...
Sometimes when I turn the ignition to ON and press the clutch slightly,
I can hear an on/off clicking sound coming from behind the glovebox.
It's the same noise as the indicator relay makes when it's flashing.
Car still starts fine :?:
Could anyone suggest as to which relay could be the culprit ?
If there was a fault would VAG-Com pick it up ?
That relay sound is normal in ABS cars.
My G60 does exactly the same at startup.
And in the traffic too! When i am pressing the brake pedal for too long... :roll:
Don´t worry mate! 8)
Hmm... I havn't noticed it on mine, it might be a slight fault or one of those things that alot of people get so we think its a 'feature'
I'd be temped to change the ABS realy (about £7) and see if it goes away....
