reggiebaby 10 Posted February 13, 2017 Hi can anyone tell me what the panel is called that is on the bottom of the front cross member/rad support, or is it all one panel. Thanks Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted February 13, 2017 the radiator carrier is seperate from the the engine cradle Quote Share this post Link to post Share on other sites
reggiebaby 10 Posted February 13, 2017 the radiator carrier is seperate from the the engine cradle Ok thanks, so to get it out will need to support the engine and remove the mount. It needs to be gone more rust than metal. Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted February 13, 2017 Just support the feont of he engine and release the mount nut then the big 17 on either side to get out as one unit the you can separate them by removing the smaller bolts. Remember to soak the bolts prior to removal to ensure none break Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
reggiebaby 10 Posted February 14, 2017 Ok got it out no problems, looking for a replacement if anyone can help think the part number is 535199171G. Thanks Quote Share this post Link to post Share on other sites
reggiebaby 10 Posted March 15, 2017 Anyone know the part numbers or where I can get replacement bolts for the radiator carrier and engine cradle 2 small and one large each side. Thanks all. Quote Share this post Link to post Share on other sites
