VR-Sixy
Scratches on Driver Side Door Glass
I've noticed that the replacement driver side door glass has quite a few scratches on the outside and i wondered if there's anything you guys would recommend to get rid of them. The glass that went into the door after 'the incident' was from an old door i had knocking around, and although i noticed it at the time, i didn 't realise how much the scratches would bug me!!
I have found this for windscreens.....
http://www.frost.co.uk/extra-polishing-powder.html
And i guessing i can use this for the door glass as well. Would welcome any input.....
Thanks.
That might do it. I had a similar issue with a scratched passenger side window caused by the trim scraping it and just bought some Cerium Oxide online and used it with a Dremel polishing pad. Works great. There's a slight distortion along the line of the scratching if you look hard for it, but otherwise it looks fine and I never notice it.
I suspect that polishing kit has Cerium Oxide in anyway, it seems to be the default choice.
