ryan_welshman
Headlight switch kills the car!
Hey people!
Hopefully someone can help me with this as its getting on my moobs!
Car died randomly the other night and then came alive then died so i had to my very first tow!
Im thinking it could very a faulty aftermarket ecu or faulty crank position sensor.
But having a fiddle earlier, i found when you switch on the headlight switch, the gauges go crazy and kill the engine sometimes.
Please see attached video any help or suggestions would be amazing
Many thanks
Sent from my SM-N9005 using Tapatalk
Electrics can be a nightmare...I would get an auto electrician to take a look unless your good with this kind of stuff.
Have you checked the fusebox, I had issues with some wires that had come loose and the car would just stop randomly and also the clocks didn't work correctly (not like yours tho..)
Edited by Dogma
Hey thanks. I did find a little green plug that had come loose but i cant see where it goes as the fusebox only comes out so far.
Googled a pic of the rear of the box and can't see anything that would help to locate where it should go... the search goes on!
Mine was a real mess of wires be hide the fuse box it was only a matter of time!
All sorted now Thankfully :)
Good luck with your endeavours Ryan.
I was going to suggest the ignition switch ? Have you changed Yours lately, as they are another source of being a pain.
Just a thought
Sent from my SM-G900F using Tapatalk
Just a thought
Was replaced last year from a a vw dealer one
