VR6 Lee
Oil light vr6
Started corrado up today and the oil light does not light up on the 3rd turn of the key(system check). Checked oil level and its all ok so has the bulb gone pop?
Could be the sender, or connection at the sender.
Sent from my iPhone using Tapatalk Pro
I'm pretty sure if the sender or the connection had gone the bulb would be illuminated constantly as it would show as a fault.
