1200 bandit 10 Posted May 10, 2017 Hi O/S and N/S door mirrors not working I have striped the mirror switch ( some one has already cleaned the switch looks all there) Have live feed to 2 wires and a earth on the wiring block to the mirror switch Can the mirrors be removed and put a feed / earth to the mirrors to check if sized Any info welcome Quote Share this post Link to post Share on other sites
Cressa 45 Posted May 11, 2017 Could you get a copy of the wiring diagram for them and try linking across the plug you have. Otherwise it is door card off time. Good luck Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
1200 bandit 10 Posted May 11, 2017 (edited) Have removed the mirror glass give the motor a knock and it work in one direction once. The motor in the mirror looks like a sealed motor. Looks like the door cards coming off Edited May 11, 2017 by 1200 bandit Incorrect information Quote Share this post Link to post Share on other sites
Philly-R6 1 Posted May 11, 2017 Is this any help? Quote Share this post Link to post Share on other sites
1200 bandit 10 Posted May 12, 2017 Thanks for the information has really helped I have now got the mirrors working. Is it normal for the mirror switch to be push in (gos flush with the plastic trim when the button is push in)the mirrors will not adjust Just like to thank everybody for the help as this is the first Corrado l have I have a few more faults to sort out but for another time Quote Share this post Link to post Share on other sites
Cressa 45 Posted May 12, 2017 I'll look on mine later for you Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
