1200 bandit 10 Posted May 24, 2017 the central locking on my corrado is hit and miss,may be something simple as vacuum pipe . so has anyone fitted after market central locking kit,alarm.The doors are not a problem as l have fitted a alarm,central locking kit to a Manta.its the boot ,petrol flap which l might have a problem with Is the petrol flap wiring just 2 wires.How is the boot locked/open is a vacuum system same as the doors any information welcome Quote Share this post Link to post Share on other sites
1200 bandit 10 Posted May 26, 2017 Abody out there with any information Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted May 26, 2017 Have you a Bentley manual? There's a detailed diagnostic check in it. The locks including he petrol tank and boot are all vac/air actuated Quote Share this post Link to post Share on other sites
1200 bandit 10 Posted May 26, 2017 Hi No manual need to know how the petrol flap , boot lock works it is a vacuum system Has abody removed the vacuum system and fitted a after market system Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted May 26, 2017 As I said in the last post they are vac/air operated like the doors. If it were me I'd be getting the original system working correctly rather than cobbling in an aftermarket solution. Sent from my SM-T560 using Tapatalk Quote Share this post Link to post Share on other sites
Gti_Jamo 10 Posted May 27, 2017 When you fit aftermarket alarms, they just tap in to the vacuum pump to operate central locking which includes both the tailgate and petrol flap. Quote Share this post Link to post Share on other sites
1200 bandit 10 Posted May 27, 2017 Thanks for the information gents.l will check the the vacuum pipes ect.l was thinking that the vacuum system would not be compatible an after market alarm Quote Share this post Link to post Share on other sites
Philly-R6 0 Posted May 27, 2017 There is a post on VWVortex, which may assist you. Quote Share this post Link to post Share on other sites
