Guest sam1990rhodes
Audi door mod electronics issue
Guest sam1990rhodes
Have bought doors with the audi door handle mod seen here.
When unlocked the door opens fine from the interior handle and the outside handle, push the lock button on the door from the inside and pull the internal handle twice to open the door works etc.
Only problem is once ive locked the door on Clifford Alarm door fob and then unlock it again the door remains in the locked position.
Has anyone seen this issue before and can suggest how to fix it? My first thought is that because the Audi door handle has no key slot ive left the cable that used to connect to the door barrel unplugged in the door, perhaps this needs a resistor putting in line?
cheers.
I was talking about this with John at JMR, he has converted his to Audi handles and said it is a little complicated to set up, small ammount of change can cause the problems you have said.
Might be worth dropping him a PM and see if he can advise you.
