1200 bandit 10 Posted June 23, 2017 Got a 1993 VW Corrado 2.0 16v Went to get the rear windows tinted today,looking really nice drove to work no problem Drove the Corrado home drives really good with no problem (about 5 miles)stopped outside the house open the garage up try to start will not start. When turn the ignition on no ABS light on dash, The engine cranks very well,when cranking the engine the ABS light comes on the dash Have good spark, have petrol up to the vavle by the air filter have petrol up to the 5th injector.the petrol is fresh.The is no alarm fitted no cut out switch fitted Remove the spake plug ,spark plug dry ,Can hear the fule pump working Have removed the wiring to the ABS pump looking clean Any information will be appreciated Quote Share this post Link to post Share on other sites
1200 bandit 10 Posted June 24, 2017 Got up this morning,thought I just give a try engine starts ups and running ok But now l have no ABS light at all, turn the ignition on no abs light start engine no abs light on Has abody had a similar problem Quote Share this post Link to post Share on other sites
Dox 31 Posted June 24, 2017 Its common for the bulb to blow on the dash light, start the car with your foot on the brake pedal, can you feel it pulse as it does its pre start checks? Quote Share this post Link to post Share on other sites
1200 bandit 10 Posted June 24, 2017 Update, turn on the ignition on,no ABS light, crank the engine ABS light on when cranking,engine starts no ABS light on,Removed the wiring block from the ABS pump light on dash,Have not been out in the car to see if the ABS works on the road but never had to use it so don't know if it has ever worked The engine starts and runs grand Quote Share this post Link to post Share on other sites
