edzer
Wiring problems
Hi everyone,
Firstly I'm not sure I've posted this in the right place, so apologies if not.
My Mreg VR has suddenly sprouted a whole heap of electrical issues and I've got suspicions that they may all be symptoms of the same problem. It may be grounding problem but everything looks ok. All the fuses are fine.
I've lost power to the sunroof, interior light, ash tray light and lighter. I cant get the alarm to set (have unplugged the flashers and the siren in order to lock the car) and now for some reason only the passenger window is going up with the auto close. If you lock and unlock the car then the drivers one goes up.
Anybody body any ideas or had anything similar?
Also, anybody got a set of wiring drawings? Cant find any anywhere and its driving me bonkers.
Cheers in advance!
Ed
Check the wiring between the door and the main chassis, where is goes through the rubber boot. Known it before that wires break/rub in that area and even the rubber boot to break so wires rub on the metal edge.
If you look for vag documents on Google drive there's all the documents you will ever need uploaded by rubjonny on clubgti
Sent from my SM-G930F using Tapatalk
Thankyou.
