jaybo 10 Posted August 17, 2017 Hi guys. I bought a set of Vibe Slick 5.25" components for the doors that also come with a a pair of tweeters. These however are only 5cm where the dash is 10cm. Anyone know if adapters exist? I've been googling but no joy. If not does anyone have a set of burnt out 10cm + screws I can buthcer to mount the new tweeters on? Cheers Jason Quote Share this post Link to post Share on other sites
delfinis38 1 Posted August 17, 2017 I used a bit of 5 mm mdf cut a circle the Diametre of the old Nokia tweeter approx 100mm then cut a inner circle out of about 50mm which is your tweetersize. then bent a u shape bracket to hold the tweeter to the under side of the mpf. Quote Share this post Link to post Share on other sites
Dox 31 Posted August 17, 2017 On my MK3 I ripped the paper cone off and used mastic to glue the tweeter to the centre of the old speaker (presuming the grills clear the new tweeters in situ?). Quote Share this post Link to post Share on other sites
