lion
Which Porsche calipers
What Porsche callipers can I fit to the front of my corrado?
I’ve all ready got the g60 set up with bigger discs.
They also have to fit under my d90s which should be ok
If anyone has the part numbers and possibly a list of what’s needed
Thanks guys
I haven't got the part numbers but i'm running 305mm discs for a Seat Ibiza Cupra R with Boxster S/911 calipers. Just make sure they are the front calipers, not the rears. My adapters are from Creations Motorsport but i'd highly recommend getting them made elsewhere. The quality of the finish of mine are junk and as a company they really don't care once you've bought their product and have your money.
I use 996.351.425 and 996.351.426 996 / Boxster S calipers with 305mm Seat Ibiza Cupra R discs, Creation Motorsport mounts and HEL hoses.
Despite the other comments the finish on my Creation mounts is fine.
Be aware that on the Boxster these calipers run a 318mm disc so in my setup there is a little pad overhang.
As already stated be careful that you don't buy rears.
As to whether they clear D90's sorry no idea....
Have you got a pic of how they look,
I’m looking to keep my 288 discs for now
Did you notice any difference regarding the pedal travel? - Yes. Was better after I changed the wheel bearings.
My G60 has ABS again after replacing the pump!
