marks2 0 Posted October 2, 2017 All plus P&P unless marked as collection only (from just outside Reading). Photos available on request. Pearl Green Petrol filler cap - £10 GWerks 6 G60 Eprom, for use with 250cc Injectors and a 65mm pulley - £30 Alloy 65mm Pulley, suitable for use with the above. Small amount of corrosion on inside. Does not affect perfromance - £15 PSD ST5 G60 Eprom, for use with 250cc Injectors and a 68mm pulley (this looks to be a re-badged SNS chip) - £40 G60 Intercooler - £15 G60 Boost Pipes (Painted Green) - £10 Set of Dash Clocks. p/n 81 117 757 Previous owner has colour coded the needles Green (not a great finish). 6K red line. Version without pressure sensor. - £12 Full scorpion stainless exhaust from downpipes back. DTM tail pipes. - £40. Collection only. G60 Cam (Stock PG) - £20 G60 Cam Pulley (Stock PG) - £10 G60 Head (Stock PG), some snapped studs otherwise OK. - £25 G60 bare Block (Stock PG, std bore, running fine prior to strip down) - £50. Collection only. Quote Share this post Link to post Share on other sites
Dazz_G60_Wales 0 Posted October 2, 2017 Hi Mark sent you a PM on the sns chip. Would you be willing to come down to 30 if so you could post with the screws M8 Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted October 2, 2017 And the crankshaft????.... Quote Share this post Link to post Share on other sites
