Dazz_G60_Wales
Re- fitting front splitter
Hi David,
yes the reinforcing plate should fit over the inner lips of the front bumper and splitter,
if you think of two pieces of thin cardboard pressed together, and a paper clip slides over them to keep them held together,
the same principle is applied here regarding the splitter, the reinforcing plate like I say should fit / slide on over the two joining lips and then should be able to bolt it up.
You want the 5 raised L-shaped brackets going over the lip of the bumper, and the solid flat base of the reinforcing plate going over the lip of the splitter, then once all 5 bolt holes are lined up you'll be able to bolt it up.
Sometimes the 5 L-shaped brackets on the top side of the reinforcing plate, can become slightly out of alignment.
If you're still having trouble attaching the reinforcing plate, can you upload a photo or two, then one of us on this Forum can hopefully see in more detail.
Or send me a photo via WhatsApp,
I'll PM you now my mobile number.
Hope this helps
Si
