fast x
When hot!!! vr6 question?
Hi guys when my vr6 is nice and warm and i turn the ignition back on to start the car again it takes about 6 t0 8 seconds to start? wot may be cousing this?
cheers philip.
Disconnect the blue temp sender plug and connect it to the yellow one. If there's no difference, the blue sender is fine.
The temp senders live in the thermostat housing. There is flap covering them just behind the radiator fan. Lift that off and you'll see all 3 senders in a row. Blue, yellow and Black.
If not temp sender related, I'd guess your crank sensor is losing it's resolution or there may be a fuel pressure issue.
K
