Red=Fast 0 Posted July 21, 2004 how do i do that? i have no idea how. Quote Share this post Link to post Share on other sites
VR6 0 Posted July 21, 2004 At the risk of feeling Dazzy's wrath :wink: could you search for this please? There are plenty of existing threads which should be pretty exhaustive. Ta ps searching for " carbon AND remov* " is your best bet :) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 21, 2004 Remove airbox Detach the two carbon canister hoses Remove the two 10mm self tappers Pull CC out of wing Block the black hose Leave the clear hose open, but with a filter on the end to reduce petrol vapour smells. And there you have it. K Quote Share this post Link to post Share on other sites
Red=Fast 0 Posted July 21, 2004 and all of the old vacuum lines can basicly just be removed? Quote Share this post Link to post Share on other sites
ben16v 0 Posted July 21, 2004 is this suitable for 1.8 16v?? i been looking it up but am not sure! thanx :) Quote Share this post Link to post Share on other sites
Red=Fast 0 Posted July 21, 2004 well, i am planning on doing this to my digi 1 2.0L 16v Quote Share this post Link to post Share on other sites
ben16v 0 Posted July 21, 2004 cool havnt realy looked under my air box to know whats there but would be very interested in a link to a good thread if anyones got it handy??!! :oops: :) Quote Share this post Link to post Share on other sites
Neocorrado 0 Posted July 27, 2004 After you take it out whre do you relocate it??? cause on my VR i had to take it out to make room for my CAI but now i dont know where to put it so i have it right next to the motor but i knowthats not where it has to be.. :| Quote Share this post Link to post Share on other sites
corradovr6sc 0 Posted July 27, 2004 You could relocate it to a waste bin :) otherwise strap it onto the left side of the radiator. Quote Share this post Link to post Share on other sites
G60Jet 1 Posted July 27, 2004 http://the-corrado.net/.archive/forum/viewtopic.php?t=857 Quote Share this post Link to post Share on other sites
Neocorrado 0 Posted July 28, 2004 Thanks guys, i'm gonna try it ASAP and see what happens i'll keep you posted on the latest :mrgreen: Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted July 28, 2004 What type of filter do you put on the fuel breather? How much and where would I likely get one from as my local Kevscort Shop could only affer a small green filter at £22. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 28, 2004 I used a radio controlled car engine filter on the end of mine and tucked the hose into an inner wing cavity. No petrol smells :mrgreen: Any decent hobby shop will sell a filter. Get a small foam one. Quote Share this post Link to post Share on other sites
Andy Brookes 0 Posted July 28, 2004 Here's were I relocated my carbon canister if you dont what to junk it. Quote Share this post Link to post Share on other sites
Neocorrado 0 Posted July 29, 2004 Andy Brookes, How did you get it to stay like that , i'm trying on mine but it's just not working :?: Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 29, 2004 Just lose it altogether Neo, much easier and neater! Just remember to block the black hose, leave the clear hose open and leave the blue frequency valve connected or the ECU will moan. Drape a hose into the CC hole for the tank vent and pack some foam around the pipe that goes into the hole and you won't get any petrol vapour smells :wink: Quote Share this post Link to post Share on other sites
Andy Brookes 0 Posted July 29, 2004 The zip tie goes around the bottom headlamp support, the base just sits down in front of the rad support. Quote Share this post Link to post Share on other sites
Neocorrado 0 Posted July 30, 2004 Andy Brookes, OK cool ! Thanks kevhaywire, I didn't even know you can do that cause when i toke it out to put the CAI it was making this noise, i din't know what it was until i check and it was one of the hoses making a sucktion noise. if i do what you told me to do will it not do that anymore? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 30, 2004 There are two hoses connected to the frequency valve. A long black one that goes to the CC, remove that completely. The second hose is a shorter S shaped one. Pull that off the valve too and block the end of the hose and leave connected to the throttle body. No more sucking noise! Or you could just run the tank vent hose through the frequency valve system and just do away with the carbon canister, so the tank vent will fumes will be burned off as normal but disconnect it for the MOT or the hydrocarbons will be too high and it'll fail. K Quote Share this post Link to post Share on other sites
Neocorrado 0 Posted July 30, 2004 kevhaywire, i'll give it a try :) Quote Share this post Link to post Share on other sites
