1200 bandit
Central locking again
So go for a drive in the Corrado today as just replaced the in tank fuel pump.runs spot on
Found the passenger window jamming on the way down.removed the door trim,found window reg jamming on the wiring,air pipe.Wiring had not been secured and found snapped wiring
Repair and secured the wiring
When locking the car from the passenger side all locks work,when lock from drivers side boot,petrol flap,drives door locks ,but the passenger side will not lock ,unlock
The locking motor is working on the passenger side with the key
When locking /unlocking the car the air pump runs for about 30 seconds stop then runs again for another 30 seconds
Sounds like an air leak. Maybe the hose got disconnected with the regulator? Check to see if air is coming through it to the lock.
