marks2
Porsche Brake Kit
I have for sale a Porsche kit consisting of the following
996.351.425 / 996.351.425 Porsche Boxster S / 996 front calipers
Creation Motorsport Golf MK2 / Corrado adaptors
305mm Drilled and grooved discs
HEL hoses.
They were previously fitted to a 4 stud G60.
There is a small amount of corrosion on the caliper pad retaining pins.
All pistons move freely.
You'll need 16+ inch wheels to clear these monsters.
Looking for £SOLD. Pickup only from between Reading and Maidenhead.
Edited by marks2
Thanks. I ran the same calipers (albeit with different discs) on my S2 Avant.
Superb brakes.
Edited by marks2
Any 16v / 5v turbo / G60 owners out there looking to upgrade your brakes?
The kit should fit a VR although you'd need different discs (I have no idea if you can re-drill to fit the 5 bolt hole pattern).
Edited by marks2
Bump to the top. I've found and will include in the sale the HEL rear beam hoses to match the fronts.
Plenty of views. No-one interested?
To reiterate the calipers are Porsche Boxster S / 996 fronts not the inferior non S or rear calipers.
Edited by marks2
