Will.I.Dub
ABS fault codes 96 8v
Evening all,
So my 8v has an inconsistent intermittent ABS light on, sometimes from cold start it's on, sometimes not, sometimes comes on when driving.
I had it scanned and the faults cleared, the same faults recur immediately. Besides the wheel sensor can you fine people shed any light on what the others might be?
Address 03: ABS Brakes Labels: 1H0-907-379.lbl
Part No: 1H0 907 379 D
Component: ABS TEVES 04
VCID: 3039EDE0433750F7C28-4AA4
4 Faults Found:
00257 - ABS Inlet Valve; Front Left (N101)
35-00 - -
00267 - ABS Outlet Valve; Front Right (N100)
35-00 - -
00532 - Supply Voltage B+
35-00 - -
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
35-00 - -
If the supply voltage warning comes up AND you do NOT have a bad battery then you either need to clean up the abs connector plug or you have a dodgy relay or a dodgy ignition barrel perhaps?
The rest points to a bad abs pump unit and obviously the sensors themselves, but work on getting rid of the voltage one first.
A Corrado is for life, not just for the MOT.
Thanks, the battery is fresh. Faulty ignition barrel? How would that affect the ABS? Intermittent power?
Yep, long shot but if it's reporting battery that means it's seeing less than 8v.
