gollfy1 10 Posted April 7, 2018 (edited) I had my charger rebuilt and have covered around 700 miles now, around 200 miles in I was under the car and noticed oil present on the charger casing, which looked to be coming from the main shaft. I have cleaned it a couple of times and it just seems to be seeping from somewhere. I have today decided to take the boost pipe off and have found the presence of oil in the charger, is this normal? As well as oil between the charger casing and some in the plastic black outlet. Its not much at all but I don't know whether this is normal https://ibb.co/ieKQXH https://ibb.co/hVv4Rc https://ibb.co/hf9QXH Edited April 7, 2018 by gollfy1 Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted April 7, 2018 I have the same with mine. Spoke to john from jmr about this and was told it was normal and nothing to worry about. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted April 7, 2018 The oil inside the actual charger may be normal but the oil leaking out from the two charger half's certainly isn't.. Quote Share this post Link to post Share on other sites
Gti_Jamo 10 Posted April 8, 2018 The only two reasons to have excessive oil in your charger (which this is by the looks of the pictures having only done 700 miles) is that you have a worn engine with blow-by issues and it's collecting via the boost return, or you have an oil seal gone inside the charger. Either way it's not normal. Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted April 8, 2018 SR_Neale said: I have the same with mine. Spoke to john from jmr about this and was told it was normal and nothing to worry about. I just wanted to clarify I was talking about a slight weeping of oil between the 2 halves of my charger and not about the amount of oil in the charger. Quote Share this post Link to post Share on other sites
Gti_Jamo 10 Posted April 8, 2018 The oil weeping between the casings could be indicative of oil inside the charger or that there is an external leak from the main shaft outer seal and oil is just gathering down there. Quote Share this post Link to post Share on other sites
virtuoso23 10 Posted April 9, 2018 Did you run the charger in after the rebuild? Quote Share this post Link to post Share on other sites
