Aaron10
bad camber after fitting coilovers
So i installed a set of jom coilovers. But now there is a really bad camber on front passenger wheel. The drivers side is perfectly straight. Any body have any ideas why it's doing this?
Thanks
Aaron
It’ll be the top bolt that attaches the hub to the suspension strut. Think it’s a 17 or 18mm from memory. You’ll need to jack it up, slacken it off and pull the top of the wheel out as far it goes and retighten.
But do also get the camber set at a garage because they drive like a dog if it's off. A good alignment setup can really transform the car's handling
