robrado974
Central locking failed again .
I sorted this a couple of weeks ago . The pipe had come off . Just locked the car and it’s come off again . I’ve noticed recently the window hits something on the way down . So off comes the door card again tomorrow to get this sorted. I wanted to go to killarton house tomorrow, to the car show , but I can’t go unless I get this sorted, as the passenger door won’t lock .
  Jon_vr6 said:
Can't you lock it with the key ?
Sent from my SM-G930F using Tapatalk
Yes Jon . Obviously the passenger door stays unlocked, I don’t have a key for that side , another issue I have to sort out . I’ve just put the window down and you can hear it hitting something, it can only be hitting the pump surely?, there’s nothing else there to make that sort of noise . I will remove the door card tomorrow morning so I can see what’s going on . Whatever is happening it’s definitely hitting the pump tube otherwise it wouldn’t keep pulling it away from the pump .
Ah the key doesn't work got you. Yeah Sounds Like The Window Is Pulling the pipe off the connection should be an easy fix.
That’s what I thought last time bud . We just reconnected it and all was well . But as I said it’s hitting something even when the pipe is off . I will take a look tomorrow. The pump may have moved off of its fixing point ?.
All sorted. Although the mechanism was fine before hand and there wasn’t any snags , it appears that when the car went in for paint and the door handle parts were replaced , they put the wire the wrong side of the sliding mechanism. Hence it was hitting it on the way down and the pipe , eventually pulling the pipe away from the pump .
  Jon_vr6 said:
Easy fix then
Yes .
