tonedef 10 Posted June 23, 2018 Looking for the pipe from the pump to the steering rack, nut on mine is rounded at the rack end. Also wanting a steering rack but plenty of Mk3 Golf ones available on eBay unless somebody here has a good one to sell. Quote Share this post Link to post Share on other sites
vw rule 19 Posted June 23, 2018 Part number 536 422 891 F £209.00 euros (Says for Corrado VR6 RHD only) Hydraulic hose/pipe goes from steering rack to T-piece near battery. (Male screwed end at rack) (Push on fitment at other end) Length 600 mm Note! The pipe above has two half's to it, the part number above is for pipe from rack to plastic T-piece. The other half of the above pipe changes to a rubber hose, which is on a different part number, which goes from T-piece to metal pipe on left side under radiator. The metal pipe under radiator is Part number 535 422 896A £95.95 euros (For all Corrados) Part number 536 422 893 C £289.00 euros (Says for Corrado VR6) Hydraulic hose/pipe goes from steering rack to power steering pump. (Male screwed end at rack) (Banjo fitment at steering pump end) Says vin n.o F 50-P-003 451>> onwards Length 1840 mm Part number 535 422 888 B £59.95 euros (Says for Corrado VR6 1992 onwards) L-shaped rubber hose from power steering reservoir to T-piece connecter in main return / feed pipe near battery. Part number 535 422 887 £76.95 euros (Says for Corrado VR6) Rubber hose goes from metal pipe under radiator on right side, to power steering pump. Part number 535 422 887E £62.95 euros Same rubber hose as above (But says G60 / VR6 also says up to vin n.o F 50-P-012 501) Part number 191 422 371B £22.96 euros Power steering reservoir All in stock at Classic Parts but if you speak to VW Heritage, they should be able to pin point correct pipe/hose, if you give them your reg or vin number. Hope this helps Si Quote Share this post Link to post Share on other sites
tonedef 10 Posted June 24, 2018 Part number 536 422 893 C £289.00 euros (Says for Corrado VR6) Hydraulic hose/pipe goes from steering rack to power steering pump. (Male screwed end at rack) (Banjo fitment at steering pump end) Says vin n.o F 50-P-003 451>> onwards Length 1840 mm All in stock at Classic Parts but if you speak to VW Heritage, they should be able to pin point correct pipe/hose, if you give them your reg or vin number. Hope this helps Si Thanks for the reply, this is the one I need, I'll check the VIN but as mine was at the back end of production in May 95 it generally falls into the latter numbers! I sent annavr6 a PM last night to see if I can buy it through Heritage or if I have to go direct to Classic Parts, I need the car for our daughters wedding the middle of next month so no time to lose getting in bought and delivered. Cheers Quote Share this post Link to post Share on other sites
tonedef 10 Posted June 25, 2018 Ordered one from Classic Parts, just hoping it gets delivered in time now! Quote Share this post Link to post Share on other sites
