hman94637
Vr6 93 Alternator Wire
93 Vr6
My son's alternator went bad and he replaced it. New alternator is not charging car. Battery Light is on in dash.
There is a blue wire that is cut on (running with) the B+ cable from starter to alternator. The blue wire is attached to the Altenator but for the life of me I cannot trace where the other wire is to reconnect it.
Any ideas what this wire is and where does it go?
appreciate the help.
According to the Bentley manual for the Corrado, the Blue wire is 0.5mm think,
goes from alternator to single connector near starter motor, then goes to back of fuse box at the bottom close to centre (says it's wire 3 in white 10 point connector plug)
It's almost directly behind where fuses 10 to 12 are, if that makes sense.
Look at the coloured diagram in the link below, it's a blow up image of the back of fuse box, look at the white 10 point connector plug ( F ) wire position number 3 is where the 0.5 blue wire in question goes to.
That I believe is your battery warning light wire.
Look at link below
http://www.a2resource.com/electrical/CE2.html
Hope this helps
Si
Thank you very much.
by chance is there a picture of what connector it goes to on starter? I'm not seeing any open connectors with a stray blue wire that would connect to my broken wire.
On the alternator there is a plug connector with 1 blue wire going out and heading straight into fuse box.
Another connector with 2 wires, one brown and I forgot the other color.
Then the main nut with the power from starter and my mysterious blue wire that is cut.
His fuse box under dash is a rats nest. I tried to get to it but I'm afraid i will pull out more wires. I'd like to see where this blue wire is cut from before I attempt pulling the fuse panel out.
Thanks!
Look at link below
Hope this helps
Si
I don't own a VR6 myself I've got a 16v Corrado, but I've found these links below of more info that could be useful to you or other Forum members.
Link below from the GTI FORUM.
https://www.clubgti.com/forums/index...thanks.186618/
And a few more links below of more info from this Corrado Forum.
http://the-corrado.net/showthread.ph...ernator+wiring
http://the-corrado.net/showthread.ph...ator%2C+wiring
Hope this helps
Si
Oooh, I get the Corrado tattooed lady with the bum following those links. I've not seen her in ages! :thumbleft:
