Yabble Dabble 1 Posted July 11, 2018 As in the title ... would like to get hold of a Metal Rocker Cover. The original plastic one is turning into a banana ... important number is 021103475 G for ABV VR6 engine. Anyone able to help out ? Quote Share this post Link to post Share on other sites
leon263 0 Posted July 13, 2018 (edited) Check out the photos below. Spotless VR6 rocker cover which has been soda blasted, etch primed and sprayed in 2 pack satin silver. Part number is 021 103 475 C which denotes that it originally came off a 2.8 VR6 .......... probably a MK3 Golf. It is identical to the Corrado cover as the 2.9 engine is just a bored out 2.8 I had it as a spare when I had my Corrados ......... now long gone. I've also got the oil filler cap which I'll throw in FOC. Asking for £35 inc postage. Edited July 13, 2018 by leon263 Quote Share this post Link to post Share on other sites
Yabble Dabble 1 Posted July 14, 2018 Check out the photos below. Spotless VR6 rocker cover which has been soda blasted, etch primed and sprayed in 2 pack satin silver. Part number is 021 103 475 C which denotes that it originally came off a 2.8 VR6 .......... probably a MK3 Golf. It is identical to the Corrado cover as the 2.9 engine is just a bored out 2.8 I had it as a spare when I had my Corrados ......... now long gone. I've also got the oil filler cap which I'll throw in FOC. Asking for £35 inc postage. Thank you for your reply, that looks great. I am assuming it will do the trick - my car is a '94 Corrado VR6. By the way, I also assume it is flat - only the garage - Clover Autos - pointed out that the plastic one that I have keep warping and if I do find a metal replacement, that it should be flat. Would you PM me ? Kind regards Toby Quote Share this post Link to post Share on other sites
