G60rob 0 Posted August 27, 2018 (edited) I sold my '92 G60 a while ago but in the process of de-cluttering to move house I'm finding a few left over bits. The boot carpet is for a full size 15" wheel and is grey. It's hardly been used, no signs of wear. The part number on it is 535 863 463 A/6FV. The nearest I've been able to find new is this: https://www.volkswagen-classic-parts.de/kofferraumbelag-fb0643.html About £150! £30 collected from Sheffield (preferred) or plus carriage. A bunch of new unused parts bought for the G60 but some will be more universal: Set of 4 Pagid T5075 rear brake pads with new bolts £10 2 track rod ends with nuts, both LH, 191 419 811, one TRW £12, one Febi £8 Pair wishbone rubber bushes 357 407 182 Lemförder and Pair wishbone bush sleeves 191 407 190A Febi £4 2 door hinge halves 321 831 403 and 2 pins 321 831 421 £10 SOLD G60 oil filter 037 115 561 Meyle £4 Blue temperature sensor, OEM, 025 906 041A £5 Crank pulley bolt OEM, N 903 208 02 £1 Clutch hose OEM 857 721 453 £4 SOLD Windscreen wiper shaft,LH, 536 955 215, Wiper shaft nut 7D0 955 243, Wiper shaft steel washer 481 955 255, Wiper shaft spacer ring 867 955 251, Wiper shaft grommet N 904 655 01, All OEM, £7 SOLD Or, preferably, to save time and trouble, all the parts (less carpet) for £45. All plus postage. Edited August 29, 2018 by G60rob Quote Share this post Link to post Share on other sites
easypops 8 Posted August 27, 2018 (edited) I’ll take all the windscreen bits plus the door hinge halves and pins and the clutch hose please Windscreen wiper shaft,LH, 536 955 215, Wiper shaft nut 7D0 955 243, Wiper shaft steel washer 481 955 255, Wiper shaft spacer ring 867 955 251, Wiper shaft grommet N 904 655 01, All OEM, £7 2door hinge halves 321 831 403 and 2 pins 321 831 421 £10 Clutch hose OEM 857 721 453 £4 Edited August 27, 2018 by easypops Quote Share this post Link to post Share on other sites
