Rocket Ron 1 Posted August 28, 2018 Hi My drivers window has packed up have check and voltage is getting to the motor even had the complete thing out and it still does not work. Anyone have one for a 94 VR. Is the passenger side the same as drivers side and does any of the other VW group cars fit ours. Cheers Quote Share this post Link to post Share on other sites
vw rule 19 Posted August 28, 2018 Hello there, I believe the electric window regulators are specifically handed to each side, so I don't think you can change them from left to right or vice versa. VW Classic Parts have stock of the left electric regulator, but the right one is still obsolete for now. I think they might possibly stock the left & right manual regulators though. There was a company online that sold after market electric window regulators for the Corrado, I'll see if they still do them. Si Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted August 29, 2018 I think i might have a spare good spare complete Unit mate. I'll check and see if it's the correct side first though. Both sides are indeed different. Quote Share this post Link to post Share on other sites
vw rule 19 Posted August 29, 2018 (edited) I've had a look online it appears that company no longer does the after market electric window regulators for the Corrado, they did about 3 years ago ARZ Tuning that is. Si Edited August 29, 2018 by vw rule Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted August 29, 2018 What is the left & right manual regulators ? Quote Share this post Link to post Share on other sites
fendervg 33 Posted August 29, 2018 They would be the mechanisms for the manual winders powered by elbow grease - used to be standard VW! Quote Share this post Link to post Share on other sites
vw rule 19 Posted August 29, 2018 Yeah as above they were only fitted to the very early Corrado's. Si Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted August 29, 2018 Anyone ordered one of these from the US A1 Automotive Accessories. Quote Share this post Link to post Share on other sites
vw rule 19 Posted August 29, 2018 No never heard of them. Looks like they've got a few parts for the Corrado though, I expect the shipping cost will be expensive ?? Si Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted August 29, 2018 I emailed them to ask them if the parts fit our uk Corrado. They said yes they do fit however due to the recent data protection changes they no longer send to the uk. Quote Share this post Link to post Share on other sites
fendervg 33 Posted August 30, 2018 What about using an address pal site that gives you a postal address in the US and then ships it back to you? I've done this a few times and works out quite well although the shipping and taxes (if caught) can work out expensive. Quote Share this post Link to post Share on other sites
vw rule 19 Posted August 31, 2018 I emailed them to ask them if the parts fit our uk Corrado. They said yes they do fit however due to the recent data protection changes they no longer send to the uk. Thinking about it this might have been the company that was selling these electric window regulators for the Corrado back in 2015 on ARZ Tuning. https://www.a1electric.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=50-54060 Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted September 8, 2019 Has anyone used these aftermarket universal window regulators, basically they operate the manual window mechanism and converts it to an electric window. Link below of the YouTube video Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted September 8, 2019 Looks like both the left & right manual window regulators for the Corrado are available, but the electric ones they've sadly sold out for now at Classic Parts. I don't think there's enough room to attach that aftermarket regulator behind the door card, plus there's the issue of the manual window winder gear stem sticking out too far, might have to drill a hole so it can protrude through the door card slightly, then put some kind of cap over it ? This might be an option for early Corrado owners who've already got manual windows ? On the Corrado the electric window regulators look very similar to the manual one, there's clearly some differences though, a part from the obvious, do you think it's possible to dismantle an electric regulator motor, and fabricate it to fit a manual one, I'm guessing not it'll be too much hassle. Si Quote Share this post Link to post Share on other sites
a_riot 0 Posted September 9, 2019 Why not fix it? Usually the motor is fine, and the mechanism gets stuck at the top. Quote Share this post Link to post Share on other sites
vw rule 19 Posted September 9, 2019 Why not fix it? Usually the motor is fine, and the mechanism gets stuck at the top. Yeah that's a fair point, I'm just thinking out load seeing what options are available, and what others think. Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted September 9, 2019 The good thing about that USA replacement regulator kit that they used to sell on the ARZ Tuning site, is that it has no cables so is gear driven. On most of the cable operated regulators they tend to get a lot of free play, where the cable frays or will stretch over time. Whereas on the gear driven one it's just the teeth on the mechanism gear, and the motor it's self that will wear out, basically less to go wrong and more of a simplified system so to speak. Si Quote Share this post Link to post Share on other sites
Sydneycl 0 Posted April 21, 2020 Would be glad to find the aftermarket window regulators Quote Share this post Link to post Share on other sites
fendervg 33 Posted April 21, 2020 ARZ seem to have only left hand side ones in stock at the moment - https://www.arz-tuning.de/shop/en/Electrical/Window-Kits Having said that, VW Classic have the OE LHS mech available as well. They used to sell a complete kit - they actually come from the US, there used to be a site where you could buy them directly. Quote Share this post Link to post Share on other sites
vw rule 19 Posted May 23, 2020 On 8/31/2018 at 12:20 PM, vw rule said: Thinking about it this might have been the company that was selling these electric window regulators for the Corrado back in 2015 on ARZ Tuning. https://www.a1electric.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=50-54060 Si This just appeared in my recommendations on YouTube so thought I'd post a link to it, basically it's a video of someone who fitted one of the USA aftermarket regulators, with good feedback. Link below: Si Quote Share this post Link to post Share on other sites
