_Matt_
Jacking points and axle stands
Hi,
I found this great thread but the pictures have gone http://the-corrado.net/showthread.php?16534-Trolley-jack-points
I want to be sure I’m jacking and supporting in the right place. So far I have only needed to jack up front.
I jack up at the rear of the subframe (or is it wishbone) mounting point to the chassis. I then place my axle stand with a hockey putt on the sill jack point. I keep the jack in situ sharing the strain. Is this okay?
I haven’t done the rear but any tips would be appreciated.
Cheers,
Matt
Done some digging and found the info and pics - sharing for others:
Generally - always use wood or some rubber on top of jacks and axle stands - hockey putt or old suspension top mount.
These are the jacking points. Best to not use a trolley jack on the seems. Either use the 2nd pic or some wood behind the seems in the green areas to jack:
[ATTACH=CONFIG]95876[/ATTACH]
When jacking the the front use the green bolt or around it if also using it to support on axle stands:
[ATTACH=CONFIG]95879[/ATTACH]
Alternatively you can use the rear of the front sub frame, but my jack does't easily reach that far.
[ATTACH=CONFIG]95882[/ATTACH]
  • Like 1
I never jack or support a car on its shell, always a subframe or axle
Yeah I usually do the middle picture. My jack is too short to reach the last picture, i need to buy a proper jack and keep my existing as a spare now I'm getting into working on the car.
Although the body parts are the factory jacking points I feel uneasy doing it now the cars old.
