Pauldancervr6
Vr6 parts needed
I'm looking for the following parts if anyone can help or point me in the right direction?
Fuel filter retaining bracket
Front panel that supports the radiator,
Rear caliper carrier retaining bolts x4
Rad support cross members are a bit thin on the ground. You can use any later one you just need to cut the sticky out bracket off yours and weld it to the other one, that is what I did for my panel in the photo.
