quicksilver 0 Posted July 30, 2004 I've just come back from the motor factors asking for a bottle of power steering fluid for my car and I've now noticed after topping up the level that its a general ATF fluid. Is this type of fluid ok to use on my car and will it cause any damage as I've only put in a very small amount (about 100ml) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 30, 2004 You need the light oil from VW. It's in a white tin with a green cap. it's pretty expensive though, well over a tenner a can but that's what the VR needs. What you've put in won't damage anything short term, but you'd be wise to flush it all out and start over with the VW fluid at some point in the near future. Cheers K Quote Share this post Link to post Share on other sites
quicksilver 0 Posted July 30, 2004 Thanks for the advice Is that the same as VW's G 002 000 hydraulic fluid - Im feeling kind of foolish right now for not checking the bottle "before" I put it in the car. :oops: Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 30, 2004 Thanks for the advice Is that the same as VW's G 002 000 hydraulic fluid - Im feeling kind of foolish right now for not checking the bottle "before" I put it in the car. :oops: The very same :wink: Quote Share this post Link to post Share on other sites
Ray1965 10 Posted May 6, 2013 Ok. I need to top up with power steering oil, its currently reading on the min mark. I have been given a bottle of LHM Mineral-based hydraulic oil and it is green, says suitable for citroens and rolls royce, and was ok for the corrado VR6. Just wanted to check before i used it if it was ok to use? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 6, 2013 The VW stuff is synthetic, part number is now G004000M2 Quote Share this post Link to post Share on other sites
