culshaw
Passenger door magic
Morning,
I'm gearing up for MOT and have passenger side door won't open from outside unless you put weight on the handle, it's really strange.
I've replaced the door catch mech. It also works fine from inside. Replaced door striker and the clip keeping the handle attached to the door.
Any idea what it could be?
Have I missed something/ fitted a non-compatible part?
Sometimes the distance between the striker and the latch it has to hit to operate the lock mechanism is to much - this can get worse over time. I've had some success in the past putting a cap or cover over the end of the striker to extend it slightly.
I just found this thread off le google. Thank you, will try this tonight
