Stone0311 0 Posted November 23, 2019 (edited) Hi, has anyone got any photos of the front engine mount bracket arrangement on a G60? Also is there more than type? The bracket that came on the engine is 1H0-199-273-D which doesn't match Etka (357199273) Thx Edited November 23, 2019 by Stone0311 Quote Share this post Link to post Share on other sites
vw rule 19 Posted November 23, 2019 (edited) Hello mate, I think you might have the wrong engine mount bracket on there, as part number 1H0 199 273D comes up as VR6 on ETKA. VR6 Corrado engine mount bracket according to ETKA Part number 1H0 199 273D with manual gearbox https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/engine-mount-bracket-front-no-longer-available/1h0199273d/ Part number 1H0 199 273C with automatic gearbox (difference of at least 1/2" between this 273C and 273D) For all 4 cylinder Corrado's the engine mount bracket should be as follows: Part number 357 199 273 with manual gearbox https://www.ebay.co.uk/itm/VW-Passat-B3-9A-Kr-Engine-Bracket-Mount-357199273/292818857955?hash=item442d5d2fe3:g:~nYAAOSwJihcq5Dg Part number 357 199 273A with automatic gearbox Hope this helps Si Edited November 23, 2019 by vw rule Quote Share this post Link to post Share on other sites
Stone0311 0 Posted November 23, 2019 Thanks Si, looking at the bolts etc from when i took it off the previous owner must have bodged it at some point. Looks like the parts quest continues then...cheers for the ebay link Quote Share this post Link to post Share on other sites
vw rule 19 Posted November 23, 2019 No worries. I'd speak to VW Heritage as they might have stock of the mount bracket you're after, looks like the MK2 Golf uses the same bracket but part number is slightly different. Part number 191 199 273 cost new £15 to £18 in stock Fits the (KR) 1.8 16v Golf but should also fit the (PG) G60 The secondhand ones for the Corrado go for stupidly expensive prices on Ebay. Si Quote Share this post Link to post Share on other sites
JoshNice 10 Posted November 29, 2019 Just out of interest I recently purchased the mount your after instead of the VR6 Mount which I need, would you consider a swap? Quote Share this post Link to post Share on other sites
Simeon 0 Posted November 29, 2019 No worries. I'd speak to VW Heritage as they might have stock of the mount bracket you're after, looks like the MK2 Golf uses the same bracket but part number is slightly different. Part number 191 199 273 cost new £15 to £18 in stock Fits the (KR) 1.8 16v Golf but should also fit the (PG) G60 The secondhand ones for the Corrado go for stupidly expensive prices on Ebay. Si None of the Mk2 brackets will fit as these are for 020 gearboxes and the Corrados all have 02A 'boxes Quote Share this post Link to post Share on other sites
