carrots
G60 front caliper slide pins
Can anyone tell me the front caliper slide pins part number. I want to fit new ones to mine when I paint calipers next year.cheers
Hello there,
according to ETKA it's listed as below:
Protective boot/sleeve set for guide pin
Part number 8E0 698 470B
Slide guide pin with pad carrier (up to 1991) up to VIN 50-M-027-000
Part number 857 615 125
Slide guide pin with pad carrier (after 1991) after VIN 50-M-027-001
Part number 357 615 125C
You might find a set of slide guide pins on eBay, or if you enter part numbers into Google it should hopefully show you other options.
Hope this helps
Si
I think this is the correct measurements but you'll need to check with your old one.
Pin Shaft length 59mm
Thread size M8 X 1.25mm
Brake carrier measurements ending 125
Length 182mm
Width 105mm
Height 85mm
Weight 1.05kg
OEM Make: Girling
Pin Shaft length ?? Not sure about length on this one could be difference of 2mm ?
Thread size M8 X 1.25mm I think ?
Brake carrier measurements ending 125C
Length 185mm
Width 105mm
Height 85mm
Weight 1.18kg
OEM Make: Girling
I'll see if I can find anything else.
Hope this helps
Si
Edited by vw rule
Think I will have yo take them apart next spring to measure them as the chassis number is a 16v .someone fitted the g60 brakes in the past
Regarding the 16v slide guide pins,
this is the info according to ETKA.
Slide guide pin with pad carrier (up to 1991) up to VIN 50-L-012-851
Part number 443 615 125B
Brake carrier measurements starting 443
Length 185mm
Width 95mm
Height 78mm
Weight 1.08kg
OEM Make: Girling
This one is possibly obsolete now ?
Slide guide pin with pad carrier (after 1991) after VIN 50-L-012-852
Part number 357 615 125B
Brake carrier measurements starting 357
Length 185mm
Width 95mm to 100mm
Height 78mm
Weight 1.08kg
OEM Make: Girling
Can't really see find anything else.
Hope this helps
Si
The Slide guide pins possibly are £8 to £12 for a set per side.
Pad carrier complete with slide guide pins are £25 to £50 for aftermarket ones, but for OEM from Classic Parts or through Heritage, are something like £150 each.
The only part number/item that I think is obsolete now is 357 615 125B
All the others listed in above posts I believe are still available.
Hope this helps
Si
Edited by vw rule
