r0adrun3r
Vr6 Camshaft position sensor (G40) Open Circuit/short with power
Current getting this and idle speed regulation adaption limit exceeded.
I have replaced the camshaft sensor with two different sensors just to make sure.
I have 12v from 1-3 pin the connector and 5v from connector 2 (signal wire.)
I have checked line 2 to the ecm pin 44 and even the solder point on the back of the board and im getting Continuity.
Is this possibly a broken ecm ? i have checked everything at this point but does anyone have any tips ?
I have even cut the 5 v cable at the connector and ran it straight to the ecm.
Is there anything else i can check without a oscilloscope?
I seem to remember someone in the past had a cam chain sprocket without the sensor pick up fitted?
I haven't looked at the sensor pick up tbh as it doesnt mention it in any of the books. Cheers for the heads up ill take a look tomorrow to see if i can find anything. Someone has told me it may be another sensor cause it to bug out but not too sure where to start with that.
