Guest abyshua
need help for my g60
Guest abyshua
Hello ,
i've got problem with my corrado g60:when engine is cold everything is fine(starts very good,idles correctly etc.).when engine get top warming and i stop it . I leave the car with engine off for 10 min.and when i started again ,engine start for 1-2 seconds and off....now will not start till i press the pedal(open throttle)let the air get in and will start normal.if i turn engine off and i start again straight on it's fine.(i think it's that time with engine off 10-15 min.somethink).
I replaced the :isv and blue coolant sensor!!!
Thanks...
