ferarrifeet 0 Posted May 8, 2020 I have bought a set of Febi rear wheel bearings for vr6, does anyone have any feedback on the quality of this part or could recommend an oem part. thanks Quote Share this post Link to post Share on other sites
fendervg 33 Posted May 9, 2020 Febi should be fine - I've always used VAG, but not sure if they are available still. Are you also replacing the discs, as the bearing races need to be pressed into the disc housing? With rear bearings, the most important part is plenty of grease and proper adjustment - you should check them again after a few hundred miles and then once or twice a year as they will develop play over time as they wear. Usually, if you are doing the rear wheels, you would do discs, pads, bearings and ABS rings all together on both sides. Quote Share this post Link to post Share on other sites
ferarrifeet 0 Posted May 9, 2020 thanks for reply, yes i'm replacing everything, just didn't know if Febi were reliable. Quote Share this post Link to post Share on other sites
