Helmert3 11 Posted July 3, 2020 Hello Everyone So the Corrado G60 (Which i have continues to try and save) is up and running again, however it seems that with the ECU being repaired too much damage was done, the Internal MAP Chip was completely fried. The Car wont fire up at all with that ECU or Chip....So i thought alright, lets see about sticking that chip in my confirmed working and supposedly stock ECU...But after cracking it all open, there wasnt a stock G60 Chip in there....Nope there was a SNS Tuning Stage 5 Chip in there... Which could explain why the only working ECU i have makes the car run absolutely awful. What i was sold as a Stock ECU, has actually been an overkill tuned chip for a most likely specific. Now the ECU that came with the car is completely dead...But I think a Stock G60 Map could help bring back some stability to the car. The big question is, where do I go about getting a Stock G60 MAP Chip. Ive seen a few for sale for around £90...But thats quite steep for a flashed EPROM, are there any cheaper options. The Chip In my Working ECU: Quote Share this post Link to post Share on other sites
ger040 4 Posted July 5, 2020 i would think you are going to need to get a known working standard g60 ecu and have a basic set up carried out the running issues may be down to other items Quote Share this post Link to post Share on other sites
WalterFarmer 0 Posted August 19, 2020 i think you shoul get your car checked. It'll help you find the issue and you can replace the broken parts. Quote Share this post Link to post Share on other sites
KarlosG60 2 Posted October 3, 2020 Did you try dealing with a specialized workshop? Quote Share this post Link to post Share on other sites
Helmert3 11 Posted October 3, 2020 Currently got ahold of a Stock G60 MAP Chip, and am making some progress. The car will now idle semi-reasonably when I unplug the blue temp sensor. Things are still lumpy, and the car isn't particularly happy, I'll most likely post a video update showing the car running later on. Quote Share this post Link to post Share on other sites
