Micky Blue 10 Posted July 25, 2020 (edited) Hope you are all well. Here are some more parts I have left. Glove box and front flap, no cover - 536857104A, 536857125A - £27 Instrument cluster/ speedo surround trim - 536857243 - £25 Footwell/ floor air vent guide/ heating duct - 536863240 - £25 ABS pump heat sheild. Rusty, needs blasting - 536863240 - £12 Wheel nut brace/ socket wrench, original, as far as I can tell - 191012219 - £15 Gearbox change balance weight - 357711188 - £15 Harness for speed sensor loom - 357927903A - £20 Brake servo - 358614105 - £50 Power steering fluid reservoir - 191422372b - £12 Brake master cylinder and fluid reservoir - 358614301 - £25 Air vent rotary inserts set of 4 - 536819707b, 536819707c, 536819708b, 536819708c - £25 Wiper washer relay - 357955531 - £12 Hazard + turn signal relay - 191953227a - £6 Multi use relay X4 – glow plug, fuel pump, horn - 857951253, 141951253b, 191937503, 857951253b - £20 Rear wiper wash relay - 191955529 - £8 Sound absorber for central locking pump - 535862254, 535862263 - £12 Sound absorber set for seat support - 535863858 - £22 Steering column, no key! - 535905851 No other part number - £55 Stowage compartment - 536857926 - £35 Carpet cover trim strips pair - £45 Front wiper motor mechanism, some rust, check photos - £35 Under dash tray stowage compartment (passenger side) - £25 Under dash tray stowage compartment (driver side) - £25 ABS pump unit - 358614117 - £70 Throttle cable - 536721555 - £25 Door shut, kick plate decals - £20 Thanks. Feel free to PM me. All the big stuff will be in the next thread. Edited June 7, 2021 by Micky Blue No longer avaliable Quote Share this post Link to post Share on other sites
