g0ldf1ng3r 16 Posted November 24, 2020 Whilst most of my interior is out i thought it might be worth asking if anyone can point me in a direction to fix my drivers heated seat relay buzzing? it doesnt do it all of the time but more often than not & always when i want a warm bum sometimes i can turn the dash switch up & there is no noise immediately but then the relay starts buzzing like mad, other times it buzzes as soon as you turn the dash switch on the passenger side doesnt do it i think i tried swapping the 2 relays over but cant remember exactly the outcome thanks in advance Quote Share this post Link to post Share on other sites
Cressa 45 Posted November 24, 2020 I'm thinking element problem. If you switch the seat ON, but dont sit on it does it still do it? Just something to try.... or check the continuity readings of both elements of both seats for comparison. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted November 25, 2020 15 hours ago, Cressa said: I'm thinking element problem. If you switch the seat ON, but dont sit on it does it still do it? Just something to try.... or check the continuity readings of both elements of both seats for comparison. i did wonder about the element as the seat has never really got very warm when the relay behaves i will give the not sitting on it a try how would i check the continuity of the elements in the seats m8? Quote Share this post Link to post Share on other sites
Cressa 45 Posted November 25, 2020 Underneath the seat is the plug for this. Just needs discommecting and testing at the seat wires. You can see which wires go to the upper or lower pad. When I get home tonight I will give you the colours as I wrote mine down Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted November 25, 2020 18 minutes ago, Cressa said: Underneath the seat is the plug for this. Just needs discommecting and testing at the seat wires. You can see which wires go to the upper or lower pad. When I get home tonight I will give you the colours as I wrote mine down excellent that would be great thank you - pics would help if you are able to as well m8 any idea if the seat section & upright sections are separate pads? Quote Share this post Link to post Share on other sites
Cressa 45 Posted November 25, 2020 Top and bottom are separate pads. Give me an hour as I am only just home 👍 Quote Share this post Link to post Share on other sites
Cressa 45 Posted November 25, 2020 The wiring diagram is better Brown/black + black seem to be the lower seat part Brown/black + brown = BACKREST Cant find my drawings, but worth tipping the seat back to get at the connections Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted November 26, 2020 15 hours ago, Cressa said: The wiring diagram is better Brown/black + black seem to be the lower seat part Brown/black + brown = BACKREST Cant find my drawings, but worth tipping the seat back to get at the connections many thanks cressa!! i just wish i knew how to interpret that diagram LOL Quote Share this post Link to post Share on other sites
