Mawrick 0 Posted December 15, 2020 Anyone in here have any ideas if a HDV gearbox is a direct replacement on a car that have a JLU gearbox ?. this is on a 2.0 TDI 140HP, with a BKP engine (which at the moment have a defective JLU gearbox). Any tips would be appreciated 🙂 Share this post Link to post Share on other sites
vw rule 19 Posted December 16, 2020 On 12/15/2020 at 10:51 PM, Mawrick said: Anyone in here have any ideas if a HDV gearbox is a direct replacement on a car that have a JLU gearbox ?. this is on a 2.0 TDI 140HP, with a BKP engine (which at the moment have a defective JLU gearbox). Any tips would be appreciated 🙂 Hello there, looks like both gearboxes are 02Q which is 6 speed and have similar specs, in fact they appear to have the same gear ratio set up range between them. 1st gear 49 : 13 = 3.769 2nd gear 48 : 23 = 2.087 3rd gear 45 : 34 = 1.324 4th gear 42 : 43 = 0.977 5th gear 39 : 40 = 0.975 6th gear 35 : 43 = 0.814 Reverse gear 36 : 23 x 13 : 14 = 4.549 Final drive for (1st to 4th gear) 69 : 20 = 3.450 Final drive for (5th to 6th gear) 69 : 25 = 2.760 Code JLU (2006 onwards) = oil capacity 2.3 litres Code HDV (2004 onwards) = oil capacity 2.3 liters PDF file of the workshop manual for the 02Q gearbox with code HDV, which has all torque settings. Attachment below. Hope this helps Si 6-speed_manual_gearbox_02Q.pdfFetching info... Share this post Link to post Share on other sites
Mawrick 0 Posted December 17, 2020 Thanx appreciated, that would help 🙂 Also got it more or less confirmed from a local VW garage that they came up as direct fitment for each other so think this should be good 🙂 Share this post Link to post Share on other sites
vw rule 19 Posted December 17, 2020 On 12/17/2020 at 8:06 AM, Mawrick said: Thanx appreciated, that would help 🙂 Also got it more or less confirmed from a local VW garage that they came up as direct fitment for each other so think this should be good 🙂 👍 Si Share this post Link to post Share on other sites
