culshaw 1 Posted January 18, 2021 Has anyone seen anything like this in the UK? It seems I need to strap one on to get my rotrex working, the belt I have is +air-con length, and I want to make sure it goes around all the pulleys correctly as intended. https://www.ebay.co.uk/itm/A-C-Compressor-Bypass-Pulley-Air-Conditioning-Bypass-Pulley-Boxed-Dorman-34214/264643163808?epid=75841589&hash=item3d9df636a0:g:9OgAAOSwwNtbfxJp Quote Share this post Link to post Share on other sites
Dox 28 Posted January 18, 2021 The AC compressors I’ve seen with the clutch just have the pulley sits on a bearing that sits on the outside of the casing. If that’s the case here you could fit a completely gutted comp case with pulley and it would do the same job Quote Share this post Link to post Share on other sites
culshaw 1 Posted January 18, 2021 On 1/18/2021 at 12:15 PM, Dox said: The AC compressors I’ve seen with the clutch just have the pulley sits on a bearing that sits on the outside of the casing. If that’s the case here you could fit a completely gutted comp case with pulley and it would do the same job Great idea, just need to find a bolloxed compressor haha Quote Share this post Link to post Share on other sites
