Mattyj87 0 Posted January 29, 2021 Afternoon all, So my 53i or l whatever it is lol is running a little lumpy as it warms up, it cut out and couldn't be restarted easily, the revs have a tendency to hang, on occasion, a facebook group member suggested a throttle body clean, I've not had a chance yet, read the fault codes ended up with g45 00285 abs sensor can't clear that so assuming its a hard latch, g19 00552 potentiometer for air flow and intake air temp g42 00525, I've managed to clear these codes but the car was starting get a bit cough spluttery had only been running maybe 5 mins, any experts out there? or has anyone seen this before, don't want to aimless change parts. Cleaned out the idle control valve seems fine to me. Thanks all! Quote Share this post Link to post Share on other sites
Philly-R6 1 Posted February 14, 2021 Code 00285 - Ross-Tech Wiki (ross-tech.com) ABS Wheel Speed Sensor Front Right (G45) This wont cause your lumpy running, but could be caused by a bad sensor or a wiring problem. Be cautious with this as I replaced the sensor on my car with a new one and I still kept getting this error code. I checked the wiring and all seemed ok - I was getting a resistance of 1200 Ohms for the sensor. A few months of headscratching and dithering I bought another sensor with a resistance of 1500 Ohms and all is now well with my ABS system. Code 00525 - Ross-Tech Wiki (ross-tech.com) Lambda Sensor (G39) It may not necessarily be a faulty sensor, but something else may be wrong and this is a symptom - rather than the cause. Code 00552 Volume air flow (VAF) sensor I can't find much on this code, so probably an intake leak, or could be a wiring problem or a fault sensor? Quote Share this post Link to post Share on other sites
fendervg 33 Posted February 15, 2021 On the ABS error - could be the sensor or the ring, so possibly worth replacing both - and invariable the other side will go soon afterwards. Only pain is that to replace the rings the hub has to come off, or on the rear the disc - which is why the front ones rarely get replaced. 00552 is the MAF - could be a vacuum leak, wiring to the MAF or the MAF is on it's way out - if you can get hold of a known good one, it's worth simply swapping it out - then again I don't know how much 8v ones cost, it mightn't be too bad. Quote Share this post Link to post Share on other sites
Mattyj87 0 Posted March 5, 2021 Thanks fellas Quote Share this post Link to post Share on other sites
