davidwort 0 Posted February 12, 2007 What spec/VW code is the gear oil? my local dealer reckons he'll only charge 4 quid a litre for fully synthetic, about the price you paid, so perhaps that's what you've got, great seeing as a few years back they charged me 16 quid a litre! The quantum silver is expensive now though, I got some from GTI international for 10 quid for 5L. Quote Share this post Link to post Share on other sites
ben16v 0 Posted February 12, 2007 G052 726 A2 i just went with what the computer said, didnt think to ask if it was fully synth cars done 160k so figured it could do with a change, if you could let me know if this is the fully synth or not Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 12, 2007 from the info I can find this (G052 726 A2 ) is the spec of oil for most mk4 golf gearboxes and is mineral not synthetic and is used where G50 VW oil was originally specified, e.g. Corrado If you have a mk4 V6 or 6 speed and a few of the 1.8T's then the spec is the fully synthetic G052 171 A2 which is a slightly lighter viscosity shouldn't think it makes a hell of a difference, but I did put VW fully synthetic in mine and it was a big improvement when cold over the old oil. VW used to specify the synthetic for 'problem' gearboxes as a cheap fix before replacing a box under warranty, but in recent years it looks like the top performance cars have the synthetic from the factory. G052 726 A2 i just went with what the computer said, didnt think to ask if it was fully synth cars done 160k so figured it could do with a change, if you could let me know if this is the fully synth or not Quote Share this post Link to post Share on other sites
ben16v 0 Posted February 16, 2007 done my oil and filter today also did my gear box oil but i was a bit worried cos only about 1/2 litre came out and took 1/2l of the new oil, was parked on the flat and left it for a good 10 mins? Quote Share this post Link to post Share on other sites
Jim 1 Posted February 16, 2007 Has it improved the quality of the gear shift mate? Quote Share this post Link to post Share on other sites
Lippy 0 Posted February 16, 2007 yeah interested to hear that too Quote Share this post Link to post Share on other sites
ben16v 0 Posted February 16, 2007 wasnt bad before although did have to change carefully sometimes, will be able to say more when starting from cold although i suppose the oil was cold today when it went in only went for a quik razz after putting it in and yeah i think i could change quicker without fearing it`ll catch a gear, was really easy to do too. torx 45 and 17mm plug tool 2quid ebay or halfords and funnel and a bit of pipe ala wiki. for less than a tenner (non synth vw oil) i`d do it Ohh and i got shouted at to slow down when i was testing it (40mph in a 60) :lol: Quote Share this post Link to post Share on other sites
Lippy 0 Posted February 16, 2007 Ohh and i got shouted at to slow down when i was testing it (40mph in a 60 in reverse) :D Quote Share this post Link to post Share on other sites
ben16v 0 Posted February 22, 2007 right annoyed at my car needs a fair bit of work: bad bits: massive hole underneath the battery- needs whole new section welded up. 3 x metal brake pipes from load valve both rear calipers. both front tyres - knew they`d be close but thought they`d pass track rod end front flexi brake line steering rack gaiter both rear bearings excess play and a no. plate bulb. need to get the welding done at a garage, basically need the whole battery panel and a bit upto the strut doing, looks like a battery has leaked at some point. the earths are not attached to my chassis anymore and the battery is loose any ideas on how much? how many brake lines are from the load valve 4? should just get them all done i suppose. any ideas on how much? i`ve got G60 front calipers to go on and i think i`ve read somewhere that C&R do kits including the mk4 calipers and all goodridge hoses F&R. any ideas on how much? tyres 205/45R16 Rainsports at the moment - £70ish each side? trackrod end and steering rack gaiter - GSF or VW? how do you adjust the rear bearings? thanks :( Quote Share this post Link to post Share on other sites
coolrado 0 Posted February 22, 2007 if you need the section under the battery and cant find any scrapped corrados where you are, there are two in a scrappy in wrexham that still have that section intact. Quote Share this post Link to post Share on other sites
ben16v 0 Posted February 22, 2007 coolrado, nice one cheers not really sure what the garage will do really if they`ll just make up their own plate or what and i havent got a mechanic at the moment so its gonna be a new place Quote Share this post Link to post Share on other sites
Toad 0 Posted February 23, 2007 To do the rear bearings, take the wheel off, remove the centre cap, (hammer and chisel/old screw driver, being careful not to knacker it), then take the split pin out, pull the locking thing off and then tighten the nut slowly, until you can just move the washer underneath with a screwdriver. Spin the disk a few times, check tightness, replace locking thing, insert new split pin and cover and off you go.... TBH Your bearings might be knackered, so it would be worth checking them and probably repacking them with grease... Quote Share this post Link to post Share on other sites
Lippy 0 Posted February 23, 2007 for the cost of it - i'd redo your wheel bearings especially if you've got to get the discs off etc. If you've not done them before, chances are they be knackered anyway. On the 2.0 the rear discs are joined with the hubs so its pointless not doing the bearing at the same time. Me n mechanic mate did that last weekend, redid rear calipers, new brake discs (which include the hub), bearings and pads. Took him an evening after work, I made the brews! Quote Share this post Link to post Share on other sites
ben16v 0 Posted February 23, 2007 cheers toad and lippy, had all new discs a year ago including bearings etc so i`ll just tighten them up to get through the mot gonna get someone to do the welding for me then G60 fronts, mk rears and braided hoses throughout and all new solid lines... its gonna be an interesting week Quote Share this post Link to post Share on other sites
nia573 0 Posted February 23, 2007 There was a Corrado in Harris Salvage (behind tescos) at the end of the summer. A red 16v (H reg I think). The battery tray might be salvageable in it?? (if it's still there that is :) ) BTW when i phoned up the bloke didn't know what a Corrado was, so it might be best to go there for a look Mike Quote Share this post Link to post Share on other sites
Toad 0 Posted February 24, 2007 cheers toad and lippy, had all new discs a year ago including bearings etc so i`ll just tighten them up to get through the mot gonna get someone to do the welding for me then G60 fronts, mk rears and braided hoses throughout and all new solid lines... its gonna be an interesting week You should re tighten new rear wheel bearings after a while as they bed in a little. Quote Share this post Link to post Share on other sites
ben16v 0 Posted February 24, 2007 nia573, cheers mate i ll go havea look, you dont do welding do you? Toad, ok :oops: Quote Share this post Link to post Share on other sites
Toad 0 Posted February 25, 2007 Funnily enough, I've just re tightened my rear bearings this morning. First the handbrake seized on, and got rather warm, so whilst I was fighting with that I took the opportunity to take a little little bit of play out of them. The bearings didn't take too long at all. Quote Share this post Link to post Share on other sites
ben16v 0 Posted March 15, 2007 right i`ve finally got my car back after 2 weeks of waiting, i now have all the parts fitted, my mot :) Quote Share this post Link to post Share on other sites
Bally 0 Posted March 15, 2007 Nice one Ben, bet yr happy to get it back on the road... Quote Share this post Link to post Share on other sites
Bojmobile 0 Posted March 15, 2007 I love that feeling when you get them back after a while though - they drive great! Absence makes the heart grow fonder - but usually the wallet lighter with Corrados too! Quote Share this post Link to post Share on other sites
ben16v 0 Posted March 15, 2007 cheers guys and yes the wallet is very light :lol: Quote Share this post Link to post Share on other sites
g60greeny 0 Posted March 15, 2007 nice one,now get some drivin done!!!! Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted March 20, 2007 Back on the road! :D Quote Share this post Link to post Share on other sites
ben16v 0 Posted March 23, 2007 some clean pics of mine and samg60`s clayed - scratchx - megs step 1,2 & 3 got the inside to do tomorrow 8) Quote Share this post Link to post Share on other sites
