Damo6sar 0 Posted April 23, 2021 Hi, Can anyone help with this? My adjustable steering column pin keeps popping out while I am driving I need to pull over constantly to pull the lever and push it back Into position. Is there anything I can do without replacing the steering column? Also where can I get hold of a off side fog lens for a right hand drive? Cheers Quote Share this post Link to post Share on other sites
fendervg 33 Posted April 23, 2021 Not sure about the steering column - maybe the clamp is loose or the holding spring gone - you’d need to take the cowling off to have a proper look. Lots of people have swapped for no-adjustable columns. Late fogs are long gone NLA. Your options are second hand, but they are very expensive even for cracked ones, or a couple of companies sell replacement lenses for around 100 each for the glass. These are not always like for like, and it can be a bit tricky removing the old glass cleanly from the housing. Quote Share this post Link to post Share on other sites
