Cressa 46 Posted September 19, 2022 3 minutes ago, MJA said: Oh I see i haven't looked at my mk2 yet there. I have heard it is only adjustable on one side too. Do you have to take the outer track rod from the knuckle to adjust then or is there movement on the outer to set tracking? Sent from my SM-G960F using Tapatalk If original tie rods then only 1 side is adjustable. Most seem to be both adjustable now. Just the outer tie rod should be loosened off its locknut and adjusted to the correct positioning on the bar Quote Share this post Link to post Share on other sites
