_Matt_ 32 Posted May 12, 2024 The Koni kit comes with the bottom spring plate for the rears. You might need the top plates and the rubber bit to locate the spring The front shocks need the spring top plate 1H0412341 (VW Classic parts did them for £20ish for both, ebay sellers seem to double that), some top mounts and the nut that secures top mount to damper but everything else is in the kit to build a secondary unit off the car. The kit comes with a nut and spring washer but that is for the part that secured that top plate (bit you can see I'm engine bay that comes through the turrets, forget what it is called) I used a mixture of vw classic parts, autodoc and AVS spares in Swaffham to get the bits. AVS has a nicely organised parts catalogue online too Quote Share this post Link to post Share on other sites
daves16v 1 Posted May 12, 2024 I didn't see the bottom spring plates, I'll have a proper look this time. I use AVS and classic parts, occasionally LLL aswell. Thanks for the info. Quote Share this post Link to post Share on other sites
