Tigerfish
Rear Spoiler only raising on one side
Noticed this week when looking in the rear view mirror, the spoiler was wonky and only raised fully on one side. Other side was kind of at half/quarter mast. Is that likely to be a terminal problem on the mechanism, or just something that has come loose?
Don’t want to use the car now just in case it finishes off the mechanism completely :(
Sent from my iPhone using Tapatalk Pro
It will be mechanical as it only has one motor to drive both sides. It’s easy to take it out and inspect. Try manually moving it.
Remove the plastic cover that hides is and there is a toggle in the middle. Pull the toggle to engage it and turn to raise and lower the spoiler.
